Chris,
You stated, "The front circuit cylinder should be on the bottom of the pedal box as it gets actuated first, and the rear cylinder on top. If they are installed wrong, then the rear brakes will be actuated before the front."
Is Shelby still using the basic original design of the pedal box with a bias bar placed vertically between the master cylinders?
Thank you,
David
