Check the masters and see if it has the bias adjuster. It might be sa simple adjustment. I would put new street pads on the front. If the front pads are for racing, they will take forever to seat in and forever to heat up and work. I had this same problem on mine and it was pad related. Next, I would try a 3/4 front master. A smaller master will give you more mechanical leverage, but you will have more pedal travel. Scott
