Thread: CSX 7000 Brakes
  #39 (permalink)
Old 01-08-2004, 09:26 AM
coyled coyled is offline
One more comment. If there is no adjuster, both masters have push rods that thread into the lever attached to the brake pedal. You could back the front master push rod out a few threads and turn the rear master push rod in a few threads to get some more front bias and see if that helps. I have a hi-tech with the pbr rears and wilwood 4 piston fronts. I would bet the wilwoods are close to the same volume as the baer fronts. My front master is 3/4 and the rear is 5/8. I think the jbl cobra is 3/4 front and 5/8 rear also. Good luck, Scott.
