Old 01-09-2004, 09:15 AM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
OZVENOM,
The salsberry (Jag) differential has three different power lock combinations.
One is for 2.88 gear sets only.
Another (most common) is for 3.07 gears to 3.77 gears.
There is also a special and rare 4.10 gear that will work with this power lock unit.
And the last is for 3.91 gear sets and larger.
The gear sets are Dana 44. You can also buy a new Power Lock diff units. Jags used a 19 spline Power Lock unit.
You will also need to check that you get the right pinion flange. The old Jag pinion flanges have a different spline than the Dana 44 spline. Not a big deal just make sure you have a flange that matches your gear set.
Hope this helps
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
