I think the relevence of the master cylinder bore diameter and pressure generated is not dependant soley upon the master cylinder bore diameter, but the ratio of the master cylinder bore diameter and the caliper piston total cross sectional area. If the front and rear calipers have different piston areas, then I don't think you can compare the master cylinder piston diameters directly.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
