Under car exhaust
Good research John, that's the pic I was referring to in the archives.
Chucks Brandts exhaust system that he got from ERA appears to be similar as the one I received from them.
However Chucks is for outboard brakes and mine is for inboard brakes.The pipe angles and clearances may differ somewhat in the rear fender but one gets the idea how it's engineered. On mine, the clearances of the pipe between the frame and tire are close.
One item of mention is my exhaust guy had to do a little bending on the angle on the primary for it to set up correctly in the vehicle. Other than having to cut out the old exhaust manifolds, the installation was pretty straight forward.
Don
