Old 01-12-2004, 04:15 PM
Default Line Lock
mrud You can get a line lock from Jeg's or Summit. You will have to do some wiring to the shifter and run brake line to the soleniod. You will need a relay. power ground switch on the dash to turn the system on and off. I would get a washer tank from era and mount it in the trunk with two hoses to spray on the tires This will make it easier on the drivetrain to start a burn out any time. DON"T add Bleach unless you want the car on FIRE!!! Rick Lake
