YEH OK
WELL AFTER SEEING YOU STOP BY MY PLACE A COUPE OF TIMES I GUESS THAT YOU FINALLY ENDED UP WITH CHIP'S CAR AFTER THE FIRE.
THE DAMAGE TO THE CAR CANNOT BE FIXED WITH A SIMPLE QUARTER PANEL TYPE FIX LIKE MOST CARS. THE ENTIRE BODY WILL HAVE TO BE REPLACED AS I TOLD YOU FROM THE START. ALSO IF YOU DO NOT REPLACE THE DRIVER SIDE DOOR YOU WILL HAVE PROBLEMS. ALSO THE FIREWALL NEEDS REPLACING, THE FOOT BOX HAS BEEN BURNED THROUGH, BACK SIDE OF THE DASH IS BURNED AS WELL AS IT'S SUPPORTS,,ALL SIDE INTERIOR FIBERGLASS IS GONE.
THIS IS NO FORD FESTIVA RESTORAL WITH PARTS YOU CAN GET FROM THE SALVAGE YARD. AS I TOLD YOU BEFORE, CONTACT DON SCOTT ON THIS FORUM AND LET HIM TELL YOU WHAT YOU NEED.
THE BRAKE SYSTEM WILL NEED TO BE REPLACED FRO THE FIREWALL FORWARD...THAT INCLUDES THE VACUUM ASSIST AND THE MASTER CYLENDER AS WEL AS THE CALIPERS ON THE FRONT.
LET'S PUT IT THIS WAY, ANYTHING FROM THE BULKHEAD BEHIND THE SEATS FORWARD IS GONE OR SHOULD BE REPLACED. THE CARB IS GONE DUE TO THE KN FILTER MELTING INTO THE THROATS. THE ENGINE SHOULD BE PULLED AND GONE THROUGH DUE TO THE FIRE CREW SPRAYING DOWN THE ENGINE.
THERE IS A LOT MORE. YOU KNOW WHERE MY PLACE IS, COME BY AND VISIT.
JAY
ALL I WANT IS A NICE SWEET NYMPHOMANIAC DEAF MUTE THAT LACTATES TEQUILA
Run & Gun participant 1998-2005
