Thread: crooked ERA
Old 01-12-2004, 09:32 PM
Matt GRX Matt GRX is offline
Wink Crooked ERA?
Hey,
If the car drives and handles well........sss'allll good!
If you are concerned about the looks , you may want to think about adding spacers behind the Driver front and Passenger rear wheels to move them out to compansate. Be careful of the wheel balancing though. These things can screw things up if not centered on the rotor. Try gluing them in place! Make sure you have adequate stud remaining.
Have you checked to see if your front and rear end have been substantially shimmed on the 2 corners? Do you have an IRS rear end? An alternative to adding spacers is shimming the front driver and rear pass control arms.
I have a 289 Aurora that had been rolled and I had to deal with many of the same problems you are encountering.
Matt GRX
