Is this what you read??? If so total seal crush is .020 to .030 TOTAL.. The 010 to .015 is PER half of the seal..You may have not have enough total seal crush with just .012. Over time you may develop a leak because the seal will wear a little and loosen up and spin on the crank..Here is the complete thread for you to read..
http://460ford.com/forum/showthread....ferrerid=25042
You must pay attention to the "small" details as well or they will become "BIG" problems in the end.
I personally would do over your seal with a total crush of .020 to .030 to be safe..
Just an update on my
oil leak situation here. I believe that I have found the problem!!!! After looking at things very closely in the rear seal area, I noticed a weird wear pattern on the bearing located in the rear cap. The wear pattern was located only on the front half of the bearing, and not on the rear. This led me to believe that the seal was not letting the rear main cap fully settle on the block, giving improper seal crush, causing the seal to be very tight in some areas and a small gap in others. After chatting with a few people at a car show, one guy with a 400 Pontiac engine said that setting the crush of the rear main seal was normal procedure. He was instructed by instructions in the seal package to trim the seal accordingly allowing .020" of seal showing on each surface, the block and the rear main cap. One of my friends chatted with a guy in Vegas that builds nothing but race engines stated that he has never had any luck just putting today's new seals in without trimming some off to get the proper seal crush. He stated that he goes .010"-.015" on the block and cap, leaving around .020" to .030" seal crush. The directions he gave us was to install the seal flush on one surface and set to what you need on the other surface by carefully filing some off the end of the seal. Repeat the same procedure on the rear cap, but file off the surface on the same side so both filed surfaces will be mating each other. Use a small dab of sealer on the filed seal end and on the rear portion of the block, set and torque to desired setting.
I did this procedure yesterday and found that inserting a new Fel-Pro seal flush in the block on one side and measured the other side, I had almost .060" on just that half of the seal. On the cap, it measured around .035", leaving a total of around .095" total crush, being WAY TOO MUCH, thus not allowing the rear main cap to set flat, causing an improper wear on the bearing and an obround seal that would not hold
oil!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
With any luck, I will fire this engine today and hopefully be back tonight with a very excited report for everyone. Keep your fingers crossed!!!!!!
