Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 03-26-2004, 10:08 AM
,,so whats wrong with a stick shift anyway? Which is prefered by 90% of Cobra owners.
Ernie
  #22 (permalink)
Old 03-26-2004, 10:25 AM
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
Ernie - Wears clutches out faster on Fords. O.K. for most G.M's and Chryslers.
Woops, thought you was talking about B&M's trick shift too.
As for sticks versus automatics you know how to start it don't you? Personal preference tempered by the reqirements of what you are trying to do. ( re: your question. ) That and the fact that I'm lazy too.
cobrashock- member of the 10% club.
( Pun intended, remember the 10% club here on Club Cobra?)
Ron Shockley
  #23 (permalink)
Old 03-26-2004, 05:33 PM
Specialk's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
Question
cobrashoch, if a C6 takes 100 hp, then a 98 horsepoewr car could not even get the tailshaft to move at WOT. Also, cars switching from C6 to 4 speed don't pick up 10 mph in the quarter.
kris kincaid
  #24 (permalink)
Old 03-26-2004, 06:22 PM
Tom Wells's Avatar
Uh oh,
I get to use my favorite mantra:
If it matters what gear you're in, the engine's too small.
Tom
  #25 (permalink)
Old 03-26-2004, 06:33 PM
Unique580hp's Avatar
Cobra Make, Engine: Unique Motorcars 427 Cobra. 427 Side Oiler. Dual Quads.
Default Lentechs are awesome
Here is a link you must check out if you are seriously considering an automatic. They are considered one of the tops in the field of AOD's and EAOD's
http://www.lentechautomatics.com/
1st car was a Cobra, hopefully my last will be also!
  #26 (permalink)
Old 03-27-2004, 07:05 AM
Kris - Sorry, it does'nt work that way. Using that logic no transmission of any type, stick included would not work if you matched its power requirments. What I'm talking about here is the trannys loss'es it takes to make a car accelerate. You are correct that a 10 horse electric motor can drive almost all automotive trannys at a constant speed. What you are talking about is drive through efficiency. That efficiency is the heat producer in trannys BTW. Not the kicking around stuff we all do to these hot rods. Another way to look at the heat issue is to think of a tranny as a giant heat sink in the middle of your car. That more than anything else is why factorys switched to aluminum cases over the earlier cheaper cast iron cases on automatics. Aluminum gives up heat better you know.
cobrashock
Ron Shockley
  #27 (permalink)
Old 03-27-2004, 08:09 AM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Arrow
Hi,
A stock C-6 takes 60 HP, a blueprinted one 40.
An AOD takes 40 HP.
A manual trans takes 25 HP.
I would rather have a heavy duty trans than a "weak" link in my
drivetrain.
The car with 460 HP won't care if it's 1 or 2 tenths slower in the 1/4 , but the owner will care when he goes through 3 transmissions by not building his car for the torque capabilities of his engine.
And by the way NOBODY can let their clutch out ,gas it, shift to 2nd, faster than a prepared automatic !
Perry.
  #28 (permalink)
Old 03-27-2004, 08:32 AM
Cobra Make, Engine: CSX4000, 427
With a prepared manual, you don't need to use the clutch between gears.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
  #29 (permalink)
Old 03-27-2004, 08:37 AM
Now were talking!! I think the answer is going to be to get the car finished with the tranny I've got at present, see how it performs, and in the meantime I need to calculate the distances from using a toploader/tremec/B/H, and ensure the bracketry will accommodate all options to ease the changeover in the future, on the question of cooling, the heat factor does worry me slightly, there is a vast range of Tranny coolers available out there,what do others use ie make/capacity/setup, I'd be interested to know, thanks again for all your inputs. Dave
  #30 (permalink)
Old 03-27-2004, 08:39 AM
Perry - Re power lost; Which stock C6? Made several years and in many carnates you know. Same for the others. What do you mean by blueprinting? And by who. Very subjective you know.
I think your numbers are a bit low but thats o.k. by me.
As is Linetechs advertised high power handling capasitys on what I call the "Art Carr" AOD special. Their power handling capacity has gone up pretty substantially from just a year ago. Yet I see no change in componentry listed. As Spock would say,,, interesting! Hmmmmmmmmmmmmmmm.
Cobrashock
Ron Shockley
  #31 (permalink)
Old 03-29-2004, 07:55 AM
Dave- Re; trans coolers. This is one area where bigger is better. Looking at a old Jegs cat. there or several w/fans I would consider, but I would have to see anything I would buy first.
More than anything else you are limited to the size of your cowl opening unless you mount it higher on the radiator. Strange as it may seem, I am using a Mopar kit unit that they sell for full size van conversons. Works for me!
cobrashock
Ron Shockley
  #32 (permalink)
Old 03-30-2004, 12:34 AM
I'll have a look at some different units, thanks Ron. Dave
