Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
January 2025
26 27 28 29 30 31
Old 09-30-2006, 12:57 PM
Cobra Make, Engine: West Coast, 533 BB Ford
Default 460 Ford Distributor Height
I have a 460 Ford in my West Coast Cobra. The height of the distributor
from the manifold to the top of the wire boots is 8 1/2 inches. This height
does not allow me to use the cast Cobra air cleaner supplied with the kit.
I do not know who manufactured the distributor, it's billet with a blue
cap in conjunction with a MSD 6 series ignition.
I need a billet distributor that is at least 1 inch shorter to clear the air
cleaner. Does anyone know if the is a shorter distributor with a centrifugal
advance. There is a photo of the distributor in my photo section.
Old 09-30-2006, 06:31 PM
Tom Wells's Avatar
Hello Gerry,
I have the MSD 8577. Here: http://www.msdignition.com/dist_19.htm
I didn't measure from the manifold because we may not have the same manifold, so I measured up from the block: 9-1/8" to the top of the plug boots which are the MSD right-angle ones.
The tape had to bend a little to get from the block (next to the distributor hold down clamp) up the to top, so the actual height may be a fraction less.
This distributor is the smallest for the 385 I could find!
Tom
Old 09-30-2006, 07:22 PM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
I also have the 8577 small diameter MSD. It barely clears the air cleaner, but it does. I have pics in the gallery.
Scott
