Old 01-13-2004, 09:48 AM
JRScott JRScott is offline
Mike,
I have several "old" articles on jag rear ends, plus a parts break down from a Jag manual. I would be happy to send you a copy of what I have if you think you could use them. There are many more combinations of parts than I ever knew or expected. Much to my dismay I found that the '70 unit from a V12 was too wide for my body and I had to switch shafts and lower arm from a 6 cyl car. Luckily I was still able to retain the V12 brakes and bearing carrier, and now everything fits fine. The sedan parts are even wider. Email your address if you want the info or if I can be of any help as I have rebuilt 2 Jag IRS and have found some shortcuts dollar wise. My Email is JRSVOtt@aol.com .
Scotty
J.R.Scott
