McLeod Hyd T/O bearing
Hi Pat,
I've been selling the McLeod hydraulic throw out bearing for years. If installed correctly, they are OK, but any leaks or failure requires transmission removal. Some cars with a x-member that isn't removable would require engine removal too. With all of the problems in the past, I've developed an external billet fork, slave & pivot assembly that I install on a Lakewood or McLeod bellhousing so it's complete and any service would then be external. Call me for pictures or any tech info.
Thanks,
Mike Forte
781-273-9900
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
