Old 01-14-2004, 09:45 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Jordan,
Pull the manifold! If you are concerned about resetting your valves just unbolt the rocker arms (4 nuts or bolts) and keep each bolt, push rod, and lifter in the exact order they came out. Pulling the intake is the easy part unless you have one of those cast iron babies that weigh about 60 pounds. Then you not only want to pull the intake but also replace it with an aluminium manifold. I just went through this and it should take you about 3 or 4 hours unless you are interrupted with honey do's. Then it will take you maybe 3 days.
Clois
"Let's roll"
"Be part of Something Good
