Given the same quality, an H-beam rod is stronger than an I-beam rod.
As Scott said, smaller bearing journals allow for lower bearing speeds, which allows you to spin the motor faster. If you're planning to spin your motor to 8500 rpm, then get the crank with the smaller journals. If you're going to keep it uner 6500, then stock size is fine.
Pete
