Thread: Brake Worksheet
Old 01-16-2004, 08:44 AM
blykins blykins is offline
<---------------- Tinf (Air Flow)
_________T2________
Tp
Rotor Side
(K(Tp-T2))/t = h(T2-Tinf)
Again, you would have to know the temp of the pad closest to the air flow....
Solving for Tp.....
Tp = (ht(T2-Tinf)+T2)/k
On the flip side, if you know how much heat is generated (from where you convert kinetic to thermal energy, friction b/t pad and rotor), and you know the temp of the pad on the piston side, you can use:
q = (k(Tp-T2))/t.....where q is the heat generated from kinetic to thermal energy.
Either way, you're gonna have to get some sample temps or assume temperatures.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
