Old 01-16-2004, 11:50 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
The continuous loop can be emulated by looping the cables over each other and cinching the looped ends together with cable clamps. They look like mini muffler clamps in 1/8", & 3/16".
Another method is a cable stop on each cable that slides over each cable, and fastens with an Allen screw. It's not as good at equalizing the tension on both cables, but it is enough to keep the car from rolling on a slight grade.
These are hardware store items usually found in he "Nuts & Bolts" section with the lawn mower, weed eater, and snow blower parts area.
True Value type stores are usually better for nut ball pieces needed for bracketmaking than Lowes or Home Depot. Typically, the True Value type places at least have salespeople with a fair command of the English language, and are somewhat knowledgeable in home DIY projects. The one I go to has several reired guys that are veteran DIY'ers, and speak The King's English like they were born here (they were). Street rodders, restorers, automotive and aircraft kit builders frequent this place because they usually have it. And if not, they can get it from McMaster-Carr or a dozen indusrial supply houses.
