01-17-2004, 05:59 AM
Il
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
On early FE engines the pulley WAS the dampener, the later ones (maybe about '68) used a separate pulley /dampener set up. I would guess the 390 is a later model or someone has put the later harmonic balancer on it. You can swap it out if you need to use aftermarket pulleys or get an aftermarket balancer.
WDZ
