I have a spare T/O bearing since I had all my problems at Omaha in 2001. I think I may try and weld a small bushing on the fitting that threads into the T/O bearing and then use a straight fitting out of the bearing and buy a AN 3 braided hose with a 90 degree fitting on one end for the top and bottom of the bearing.
Also, just an FYI. When you buy a Billet Aluminium Flywheel the center hole that goes over the end of the crank is under sized .050 and must be machined.
Clois
"Let's roll"
"Be part of Something Good
