Old 01-20-2004, 09:54 AM
DC COBRA DC COBRA is offline
Cobra Make, Engine: BDR 89 KEITH CRAFT ALL ALUMINUM 427 WINDSOR
Gary, on other thing to consider in changing degree of cam is the piston to valve clearance. On my 514 clearance of PtV was only .085 fairly close. This was at 0 degree when degreeing cam.I played with setting it 2 degrees advances, loss about .028, valves barely touched, real tight. May not be as critical in your setup, was in mine with running over 800 lift on intake.
DON
