hedlights
I upgraded my lights to Hella lenses and bulbs. One thing that is comonly overlooked is the wiring. You only start out with13 volts so if the wiring is thin you can get a significant voltage drop. Your light output significantly drops even when there is a minor voltage drop of 1 or 2 volts. Heavy guage wire and quality relays are important. I also wired my lights to run both highbeam and low beam when the high beams are on using a 25 cent diode available at radio shack. Talk about blinding.
