Originally posted by Mike Simard
When you put the old carb back on, did you have to change the idle speed?
Yes, but I also was adjusting timing since I had the distributer out and not marked too well. So I did a little of each of those. I'm sure I ended up bumping idle up since there would be less vacuum with this direct port single plane intake.
