Old 01-21-2004, 03:35 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
You have lost velocity of the intake air charge. That plus the single plane replacing a dual plane intake means you lost vacuum signal at the carb. You may get satisfactory results by adding more fuel to the accell pump shot, or maybe even running a smaller squirter to lengthen the pump shot duration.
I am assuming that when you say it stumbles at part throttle, you really mean it stumbles as you transition from part throttle to slightly more throttle, but not at WOT.
