Mike,
I think the smog check has to be done at a special place designated by the BAR and a BAR supervisor has to be present. You can't take it to just any old smog station. When I called the BAR they set my appointment up at the auto shop at Los Positas college in Livermore. Call the BAR at 800-622-7733. They'll tell you where to go based on your zip code and they'll set the appointment up for you.
Can't help you with the bond and brake/light inspection but you might ask others here on CC to see if you'll need to have emergency flashers and a backup light installed.
So, I guess you got your rearend back together and everything is running well?
Chris
