Thread: Lucas Wiper
Old 01-22-2004, 07:29 PM
G.R.'s Avatar
G.R. G.R. is offline
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
It is not an electrical problem--Today I switched the lead to the high position--same thing--works fine without the blades--put the blades on it binds or slips--like I said before the electical is not a problem for me.
As Pat said it is probably mechanical? I can put the blades on and put minor pressure on them to "help" them complete the cycle--without the "help"(gentle pressure on the blade arm)2-3" movement on it's own.
The guide rods for the wipers are straight from the motor, no kinks, curves, etc. .
My thought is the cam gear on the motor may be worn and slipping when under pressure from the tension of the blade arms
Only thing is I can not figure out how to get the motor separated from the "worm drive" cable so I can open up the motor to check the cam gear.
Since I live in WA wipers would be beneficial.
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
