Old 01-22-2004, 11:53 PM
Andy(UK)'s Avatar
Andy(UK) Andy(UK) is offline
Cobra Make, Engine: Will Be GD427 & Ford 302
Question My Proposed Spec.
What do you guys think to my proposed 302 re build spec?
Ford 302 pre 1986 block (for UK SVA emissions).
TFS twisted wedge or Edelbrock performer rpm heads.
Edelbrock performer rpm intake.
Edelbrock 600 cfm manual carb.
Keith Black hypereutectic pistons. (Or similar to work with above heads.)
Eagle I-beam Rods (already got these).
Comp Cams 268H, lifters, timing chain set and push rods.
New cast crank (rated at 500hp. already got this)
Crane energizer or similar roller tip rockers.
Melling HV oil pump.
Does anyone have opinions on the twsited wedge heads? Are the performer rpms better or worse? And will I need to do any piston work or will they be OK with stock length rods with the twisted wedge heads?
Also is it easy to fit a windage tray to a block that normally didnt have one?
Thanks in advance.
Andy
