I just changed the bulbs and not the diode. The first set I tried were the Astra 12V 130/90W which were not as bright as the BioLight H4 12V 100/90W P43T.
They are the bright blue/white bulbs and provide more illumination than needed even in low range.
I think that if you change the diode you'd better be sure that you've upgraded your alternator to 100amp verses the normal 65. When your fans, lights and electric fuel pump are all working at the same time, it will really tax the system and heats the wires.
DDS/The First Edition
"In debates on ethically contentious issues, it is never wise nor polite to deride or belittle another person's delusion."
