If space is no issue, then the intake you choose should be based on where you want your powerband to be. You need to match your intake with your heads and cam. Lots of good information on
The Corral.
If it's a Mustang type EFI intake (like the Victor Ford 5.8L EFI), the Mustang electronics will work with it.
Here's some other intake choices:
Probe Spyder
Trick Flow 351 EFI
Hogan's Custom Intakes
Trick Flow Box Intake
5.0Mustang High RPM Intake Test
Pete
