Old 01-24-2004, 04:51 PM
magna_swede's Avatar
magna_swede magna_swede is offline
Cobra Make, Engine: AK 427 + Ford 302 EFI std, so far
Question Modification advice wanted!
Hello friends!
I'm in need of some good advice. In the end (two years from now) my engine will look like this:
Donor Engine 1987 5.0 EFI HO
High comp pistons + better camshaft + heads with roller rockers + perfomance intake manifold + injectors & mass air conversion (Speed density is present).
Now I'm rebuilding the engine in order to pass Swedish registration, that means low power engine is required for passing the test. So, I will prepare the engine body (block + rods & piston) for tuning after registration, camshaft and others will be done afterwords.
So here comes the questions:
1: Advice on pistons, +0,030, that will work with stock cam, head and intake, but also will work well with above describen modifications. (I don't want to lift the engine for tuning after registration)
2::Reboring of engine, what's max boring of stock block? +0.030 or more?
3: What's size of the combustion chamber on stock heads?
4: Does the tsock ignition system cope with +350 bhp?
5: What sparkplugs is recommended for this level of modified engine?
That's all for now, but I'm convinced that more question will occure..
Best regards Roy
http://drive.to/roys
