I made new lower brackets from square stock brass. The mounting holes are equal distant from the front edge of the frame. The frame is tapered getting larger the lower you go. Problem is the windwing crosses the rear edge at a point midway. the windwing doesn't fold flat for garaging and if bumped it breaks the wing at that point.With my longer lower bracket the wing fits the rear edge evenly .Folds flat, parallel with the side of the car and doesn't get broken as someone passes too close. Big butts and small garages.Local platers all folded so not plated yet.
Mike H
