Old 01-26-2004, 09:23 AM
craigayl's Avatar
craigayl craigayl is offline
Cobra Make, Engine: Superformance Cobra SC, 514CID
Hi Deano
I’m 6’2” and I sat just high enough the wind would catch the top of my head.
I have not heard of any kind of kit available.
I lowered my seat and moved it all the way back by removing the seat adjusters. After removing the adjusters, I made two adapter rails out of 1”x1/8” strip stock (available at any well stocked hardware store). I don’t remember the length, but they are about 3” longer than the adjusters. The rails bolt up to the seat as the adjuster rails did. To attach the seat to the floor, I put the seat in place with adaper rails attached and then marked the adapter rails with a pencil up through the original mounting holes. I then drilled holes in the rails and put bolts down through the holes to replicate the studs on the original rails. The two forward bolts are longer than the rear so I could put 1/2” spacers under the front to give the seat a little rearward tilt.
It’s been two years and 10,000 miles since I made this mod, and I have never regretted it… I find it very comfortable.
Craig – SPF 1265
