Old 01-26-2004, 10:00 AM
Snakecharmer's Avatar
Snakecharmer Snakecharmer is offline
Cobra Make, Engine: Empty handed for the moment
Send a message via AIM to Snakecharmer
I'm 6'4" and had the same concern.
The newer SPF "bladder" seats with the netting sit much higher than the old "pad" seats. I opted for the old seats at purchase to give me some height advantage. You might ask to see if someone will trade with you.
To get the seats further back I just removed the seat rails completely. After removing rails and bolts, I shoved the seat all the way back and drilled up through the frame holes from underneath the car into the fiberglass seat frame. I then bolted the seat, using large washers, directly down to the car.
This might seam crude but it gives you maximum room.
Good luck,
Charmer
_______________________
Stretch Williams
"A snake in my garage is worth two in your trailer" - me
