Old 01-27-2004, 08:16 PM
Rogers Rogers is offline
Cobra Make, Engine: Backdraft # 91, Black w/White stripes and Red Rookie's, 302 w/AFR 185's.
I don't know of anyone using stainless headers. Your best bet is to have them Jet Hotted. I've had this done on 3 Cobras...they guarantee no blueing or flaking. Also be sure to anchor the headers to your heads before you slide on the side-pipes. This will keep a good seal against the heads. Should use the Earls brand header gaskets. Part aluminum, part graphite....these will seal tight and keep your header bolts tight....good luck. By the way...ask for Tod at Jet Hot and get the Sterling finish.
