BDR Ride Height & Alignment?
The manual that came with the Roadster suggests some BMW alignment settings. But there is no mention of the ride height. Using the 15" tire/wheel combination, and assuming mostly street (vs track) use, what is the preferred front and rear ride heights? Also, please indicate where on the frame you are taking these measurements.
Is everyone using the BMW alignment specs, or have you found better settings?
Finally, has anyone experienced any coil spring "settling" after they set up the suspension originally?
Thanks in advance.
Scott Harrison
CSX4100
Growing old is mandatory...growing up is optional.
