Scott: The OEM cable set-up pulls the fork forward from the front. However, the clutch slave pushes the fork forward from the rear. In both cases, the fork operation is the same. We just activate it differently.
Our slave has a bracket that mounts onto the rear of bell housing and the rod pushes the fork forward. Your confusion comes from the fact that it doesn't bolt to the flange, which is the front side of the fork. It bolt to the rear of the housing.
Hope this helps. If I didn't answer what your asking, just give me a call.
I've got picks. I'll try to post tonight.
Robert
(817)703-1475.
