Old 01-29-2004, 01:45 PM
Tommy's Avatar
Tommy Tommy is offline
I tried a conventional banjo fitting without success. With the McLeod T/O bearing bolted to the transmission, the hose would not rotate to clear the opening in the scatter shield if the fitting was tightened down. If your application does not require the hose to move after the fitting is tightened, I think it would be ok.
Tommy
Previously owned EM Cobra
