Old 01-30-2004, 02:25 AM
decooney's Avatar
decooney decooney is offline
As I recall...my understanding is the body width is the same between the two bodies, however if you want the more pronounced lip vs. standard wide flare, material is slightly added to the inside and material is removed (cut away) from the outside until the lip becomes more pronounced. Its sort of cut in so to speak. Look at the pics again & compare how one is cut in more agressively while the standard is sloped gradually with no lip.
http://www.erareplicas.com/427/blue.htm
Duane
