Thread: New Tremecs
Old 02-01-2004, 10:07 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
The tremec has always been a good street/economy tranny. I've always thought the gearing was never right for a high hp/low weight car, as the gear spacing was too wide, wider than a wide ratio toploader, and the spread between 1st gear and 5th was so large that it made one of these two gears, depending upon the rear end ratio, unusable. With the 4617 TKO as listed, www.ttcautomotive.com/English/news/20news.asp ,
the ratio's are similar to a wide ratio toploader 2.78/1.93/1.36/1, but the toploader gear spreads are more even in % drop. Using a wide ratio toploader, with appropriate rear end gearing, you really don't need overdrive, so I'm not sure how valuable the .82 overdrive is even in this new tranny.
I think if Tremec made their trannny with 1st through 4th similar to, or the same as a close ratio toplolader 2.32/1.69/1.29/1, and then had the .82 overdrive, that would be the most ideal for a high hp/low weight car.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
