Old 02-03-2004, 09:24 AM
big_rob's Avatar
big_rob big_rob is offline
Cobra Make, Engine: FFR kit in the works
Send a message via Yahoo to big_rob
Default pollished holley 750 will sell or trade
THIS IS A NEW HOLLEY HIGH PERFORMANCE POLISHED 750 CFM FOUR BARREL CARB THAT WAS USED ON A MOTOR DISPLAY ONLY. IF YOU ARE LOOKING MORE HORSEPOWER OUT OF YOUR STREET CRUISER OR FASTER TIMES AT THE DRAGSTRIP, YOU NEED THIS CARB. THE VACUUM SECONDARIES AND MANUAL CHOKE MAKES THESE CARBS WORK GREAT ON NEARLY ANY SIZE ENGINE BECAUSE THEY ALLOW YOUR ENGINE TO ONLY GET THE GAS IT ACTUALLY NEEDS WHEN IT NEEDS IT AND CAN BE ADJUSTED TO FIT YOUR ENGINES NEEDS. AS OPPOSED TO A DOUBLE PUMPER THAT DUMPS TOO MUCH FUEL ALL AT ONCE AND ACTUALLY SLOWS YOU DOWN TAKING OFF. WE CAREFULLY INSPECT,TIGTHEN ALL SCREWS AND INSTALL ALL CARBS ON A ENGINE DYNO TEST STAND AND RUN TEST AND ADJUST THE PUMP,AIR AND FLOAT LEVEL. SO WHEN YOU GET IT JUST BOLT IT ON AND GO RACING STREET OR STRIP. THE BRIGHT ZINK WOULD LOOK GREAT ON A SHOW CAR, THE LIST # IS 3310. YOU CAN SAVE A LOT OF MONEY OFF RETAIL WITH THIS CARB. WILL GIVE YOU MORE POWER AND BETTER GAS MILEAGE. BUYER PAYS $15.00 SHIPPING IN THE LOWER 48 STATES. ANYWHERE OUTSIDE THE LOWER 48 STATES WILL HAVE TO BE ADJUSTED TO WHERE YOU LIVE. CANADA AND PUERTO RICO ARE AROUND $29.00 MOST OVERSEAS SHIPMENTS AVERAGE AROUND $35.00 FOR SURFACE MAIL. I ACCEPT CREDIT CARDS THROUGH PAYPAL
$200.00[b]
LITE'EM UP
