Thread: New Tremecs
Old 02-03-2004, 02:41 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Duane,
Actually, that 5-speed already exists, in a way that is. A Richmond 5-speed is kind of like a close ratio top-loader with a .82 overdrive. If you couple a Richmond 5-speed, substituting the 3.04 first instead of the standard 3.27, and combine it with a 3.07 rear, it would be comparable to using a close ratio "toploader 5 speed" with a 0.82 OD coupled to a 3.54 rear.
You can special order the richmond with the 3.04 first, keeping 2nd through 5th the same, making the 1st to 2nd shift not as drastic. I almost did, and in fact, I currently run a wide ratio TL with a 3.07 rear with the idea that if I thought the ratio's were too far spaced, I could just swap the tranny to a close ratio 5 speed richmond / jerico / G-force of similar ratio's without changing my rear end gears, for both performance and some economy. The wide ratio TL with the 3.07 rear is perfect though.
The jerico's and G-forces are available in many ratio's to suit anybody's taste, but expect to spend $4000-$5500. The Richmond is alot cheaper, but not as good of a tranny.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
