Old 02-03-2004, 04:24 PM
Mark Roe Mark Roe is offline
Cobra Make, Engine: CSX4285, Shelby aluminum block 427, 40th Anniversary Model # 5
Default Tires
Ed--
As Hal said, if you want the origianl look--stay with the 15" rims. If you do, your choices are limited to good tires. BFG Drag Radial or Nittos are two examples of tires that work well on the 15' rims. If you decide to go 17'--then your choices are vast.
Also, how are you going to drive your car. Race--street--show--should help you making up your mind..
Good luck and welcome to the Cobra world.
