Old 02-03-2004, 09:06 PM
Rodney Rodney is offline
Cobra Make, Engine: #901 Superformance 427cid 540hp!
Wink The details
Geez, Thanks for the interest.
The tank is made out of 050 304 brushed stainless steel.
Fully baffeled, tig welded in 22 gallon capacity.
The tank will fit into the same location as the factory SPF tank using the four mounting points without the use of the factory fuel tank straps, instead brackets welded directly to the new tank provide the mounting points for a cleaner look.
Two -10AN oulets mounted along the bottom forward edge which will feed a fuel pump more efficiently and two -10AN return fitting mounted at the top forward edge along with a -08AN vent line are welded to the tank along with a relocated fill pipe, which will be connected by the filler cap by a single piece of 2"ID fuel fill hose as opposed to the two hoses and metal elbow on the factory tank, a center mounted autometer fuel level sender or the factory sender could be mounted. The tank will be completed this weekend. And hopefully some better photos to follow.
Tyfaim, if your available how about dropping buy the shop for some digital photos, I don't know how to make the photos smaller to attach in these posts, so thanks for the help! I plan on offering the "Big tank" asap! If your interested in a tank or have a constructive comment please email me Rodscobra@shaw.ca
Thanks again guy's. Rod
"This year Ferrari's Ass Is Mine"
