Old 02-04-2004, 09:08 AM
mzhun mzhun is offline
Cobra Make, Engine: B&B, 396W Southern Automotive Stroker, Custom 8.8 by Fabrication Concepts
I just installed the chrome flex hose. It should disipate more heat and the kit has plenty of tubing to do both upper and lower. The Chrome fittings put the clamp too far back so you have to really make sure they are pushed up as far as possible and really tighten them down. Mine blew off a couple of times and you can see in the pic that I had to turn the radiator fitting around to make it work.
