Old 02-04-2004, 11:11 AM
DAVID GAGNARD's Avatar
BroncoMan;
If all your getting is a backfire every 15/30 seconds,I would think when you replaced the distributor you do not have it on #1 cylinder.. Your getting fuel,but if no fire or fire in the wrong sequence,it will not start....
Try checking and making sure #1 cylinder at TDC and see where your rotor is pointing,then go from there.... This is the easiest thing to check first.....
David
DAVID GAGNARD
