Old 02-07-2004, 01:44 PM
BlueRooster's Avatar
BlueRooster BlueRooster is offline
Cobra Make, Engine: SPF #623 460/4x2
I had this happen twice while taking the carb on and off to change main jets. The float bowl was stuck. Unscrew the bowl adjustment, and move the float a little, turn the pump on and check it again till it stops. Do a final adjustment to make sure the level is right and you should be good to go.
Dane
