Old 02-09-2004, 08:17 AM
ItBites's Avatar
ItBites ItBites is offline
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
Lugnuts should NEVER loosen if properly torqued and the studs are installed correctly and the hub/wheel surfaces are wiped clean during assembly.
You'd better worry if your lugnuts ever loosen up about the construction of the car.
You still might want to check them, but if they are loose, be concerned about the installation of the studs and when they will loosen again!
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
