Old 02-09-2004, 09:45 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Index the disributor one tooth in the direction you need it to turn.
Mark the dist base for where the rotor is pointing. Remove dist partway, rotate one tooth, drop back in, re-align the rotor to base marks. Check timing.
