Old 02-09-2004, 01:53 PM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
There are two ways of doing it:
1) Cheaper way - use the FMS kit you mentioned, which will require you drill & tap holes for the spider bolts, and use a small base circle cam. The small base circle cam is required because the lifter bosses in your block are too short to hold the roller lifters if you use a regular base circle cam.
2) Use lock bar lifters like the ones from Crane: Crane Lock Bar Lifters , and a regular base circle cam.
Pete
