Originally posted by A Snake
I've never been under a real Cobra to see how the diff is mounted to the chassis, but the Jag actually has a steel cage which holds the entire rear suspension and the cage in turn is fastened to the chassis.
I'd like very much to know how an original Cobra is hooked up if Tom would be so kind as to share that.
Al... not 'original', but as REAL as i can get for you tonite.
Pinion mounts, as shown... "ears" at rear, mount to frame...
